Chapter needs machining and welding help in Northern California
Chapter 1432 in Stockton has two Thorp T-211s donated by Indusav for assembly by our students at Stockton Airport (KSCK). Unfortunately, some of the landing gear parts were unavailable. Dr. Ram Pattisapu, CEO of Indusav, sent us the necessary drawings to make them or have them made, though. We need pistons, piston bearings, and axle assemblies made. The pistons are thick-walled 4130 tubes that require turning on a lathe, hard chroming, and welding. We have a set for one airplane, so we need two main and one nose landing gear piston. The bearings are turned from 2024-T3. The axle assemblies are 4130 tubes welded together. We need four main and two nose gear bearings and four axle assemblies.
If someone is interested in helping us get these projects moving, it would be greatly appreciated. Our chapter is a 501 (c)(3) organization, and we're working with another local 501(c)(3) organization that's dedicated to getting young people into aviation. We have some money to get this done, but it's limited.
Send me a PM if you can help. I'll reply with contact information
Gary Prost
Chapter 1432
