Would the EAA flight test manual and test cards be at all useful for a helicopter?
I’m not a helicopter pilot, so take this with a grain of salt. I would assume most of the test manual and cards would be applicable. Some would probably need some modification. And of course there’s testing you would need to accomplish that’s applicable to rotorcraft and not airplanes. So the manual would most likely give you a good foundation to start with if you have no other references. If you haven’t already, I’d also review the latest version of the FAA’s Amateur-Built Aircraft and Ultralight Flight Testing Handbook, AC 90-89C. https://www.faa.gov/documentLibrary/.../AC_90-89C.pdf
PP ASEL - IA
RV-10 N728TT - Flying
EAA Lifetime Member
WAR DAMN EAGLE!
Thanks! I can build from there. May or may not get EAA document based on what I can learn about it.
Thank you. This will help a lot. I have drafted a plan, but will add some of the detail here, and probably several more items.
I have Mirocopter on order (arriving next week) and as I mentioned in another thread (Experimental Exhibition conversion from UL (eaaforums.org)), I want to convert if from UL to Experimental Exhibition. At first glance, I am not too far off in my overall plan. I fully intend to follow it, but I also want to use the test cards, test plan, videos/pictures, etc. as part of my submission with the application. DERs with helicopter knowledge seem in short supply, or my search capability is poor.
Ernie
