Results 1 to 4 of 4
Thread: C-65 Engine Mount for J3
    Feb 2012
    Sarnia. Ontario Canada
    Having issues making an engine mount in SW.
    Can't figure out how to run the tubes and make them mate correctly.
    Apr 2021
    Finland
    When I made the WAR FW-190 mount, I found it easier to add sketch planes instead of 3D-sketches. You will have to define points where all tubes meet, define planes through the points and draw sketches with lines on these planes. Then you can use Weldments to place and trim tubes. You will probably have to define seamless tube sections if you use weldments.
    Apr 2021
    Finland
    I made these mounts for O-320 and O-360 Dynafocal with Catia about ten years ago.
    vondeliusc's Avatar
    Kalispell, MT
    Arrow
    Quote Originally Posted by rkirk77 View Post
    You have the mount T's, use a 3-D sketch in space for use in creating extrudes.
    Roll back the feature tree, show the planes and sketches and 3-D sketch to understand the process. Hope that helps; just continue using the same process, and use 'feature scope' selections.
    See downloadable example: https://www.dropbox.com/s/a8n9p79zeq...nt.SLDPRT?dl=0
    Name:  J-3 C-65 partial mount.jpg
    -Christian
