Hi Ivan:
Thanks for the additional resources - I'll check them out. I appreciate the budget approach, and I suspect ultralight folks mostly share that in common. In fact, I think that's probably a driver for most homebuilders. It certainly is for me. Didn't think of the liability issue, but I'm not an engineer. Curious to see how you design the fuselage - not sure how you're going to avoid making it out of aluminum foil given FAR 103.
Michael
