Results 1 to 10 of 11
Thread: Cleaning a fibreglass tank
    Hi everyone,
    I'm new to the forum. Does anyone have advice on cleaning gasoline resin off a fibreglass tank which was allowed to become dry. I have added some gas to the tank and it comes out clear but I’m concerned that resin may flake off the walls of tank.
    Thanks for suggestions.
    Brrrmidji , Minne-SNOW-ta
    Can you put a roll (or more) of Quarters in it and move it around with fluid...
    Or Nickels.....( nothing that might spark )
    Count them when your done.
    Quote Originally Posted by 99charlie View Post
    Hi everyone,
    If the comment "gasoline resin" is actually sloshing compound then you may have a serious problem.
    Over time the sloshing compound can turn to goo.
    Thanks for your reply. Once they are in, I don’t know how could get the coins out of the tank.
    Thanks for reply Bill. I intended to say ‘gasoline varnish’, ie the coating left on the walls of the tank when the gasoline has evaporated. I don’t know how to remove the varnish without damaging the fibreglass. I will add some fresh gas and slosh it around in the tank, then drain to see if any varnish flakes come out.
    I guess you can't remove the tank ?
    This was the only way the coins would work... By tumbling them around in the tank.
    Turning the tank over and shaking until the coins were out.
    Sounds like a big fuel filter is needed...
    Removing the tank will be very difficult, but if that’s the only option, I will do it and try the coins. Thanks for suggestions,
    Push a frayed rope inside and slosh it around.
    I’ll try your suggestion. Thanks
    cub builder's Avatar
    North Central AR
    Personally, I would use the cleaning solution (KBS Klean) from KBS coatings. I have used it on Aluminum and composite tanks to clean and prep for repairs with very good results.
