So you're fine with having the fuselage fail. Or the tail failing. You just don't want the wings to fail?? Personally I don't want any failures and that means all the parts have to work together and have matched capabilities. I predict that if you cobble together a Frankenstein biplane you will not be happy with either the effort required or the results.
Well said.
I've seen EAA Biplanes flown in Basic and Sportsman events, even beating out the big $$$ monoplanes flying in the same events.
Wouldn’t that be more of a function of pilot skill vs type aircraft??? I thought basic and sportsman class was setup to level the playing field
Unless you know the failure mode of the EAA biplane, you don't know if just replacing the wings will provide an advantage. Maybe it's not the wings that fail first...maybe it's the cabane struts, the interplane struts, the flying-wire attachment points, lower wing attachment points on the fuselage, etc. Or even the engine mount, horizontal stabilizer bracing, etc.
You said earlier that the EAA Biplane is "rated for +/-9 G"... is there any sort of supporting documentation? Test data? Years ago, a friend took over marketing of a fairly common homebuilt aircraft. He found the previous marketing chief had claimed the design was aerobatic and had published all sorts of graphs...but there was NO data to back it up. My friend suspects the previous guy made it all up to sell more airplanes.
A better question might by *why* your airplane is placarded against aerobatics if it supposedly was "rated" for 9Gs. At one point in the past, the FAA did seem to be just including "no aerobatics" as a blanket prohibition, unless the builder asked for it not to be included.
Finally, doesn't hurt to ask, but the EAA Biplane fleet is so small (71 aircraft) that you're unlikely to find one with a specific hybrid modification. AND to ask for proof of a specific degree of stress testing.....
I've actually come across Pitts Specials that had operating limitations that prohibited Aerobatics!! Definitely not because the airplane isn't rated for same!! Usually, this happened because neither the applicant nor the FAA inspector really read the operating limitations, or understood the aircraft in question.
A placard prohibiting aerobatics may have been simply added by a previous owner on a whim! There is certainly no structural reason that I'm aware of in an EAA biplane that would preclude aerobatic maneuvers.
Cheers!
Joe
The EAA biplane evolved from the Gere Sport and I think four aeronautical engineers were involved in updating the design and drawing plans. Bud Gere was 19 yrs old when he designed the Gere Sport so I'd wager the engineers were "thorough" in the redesign process. Have there ever been any structural related failures?
My understanding is that to have operating limitations that "approve" aerobatics you must fly and log aerobatic figures flown during Phase I flight testing. Which is to say that you fly loops, slow rolls, snap rolls, and spins. That pretty much covers everything and you are good to go. Builders who are not interested or do not have the competency likely wind up with the limitation. But you can have your operating limitations updated to remove the restriction if you are willing to demonstrate the capability.
