Continuing on with the tank build. Another change the builder wanted was to alter the tank mounts. On the original Fokker tanks the mounting brackets are riveted an soldered to the tank. He decided to go with a more modern approach, straps. So I added some beads to the tank to locate and support the straps.
Checking the fit of the bulkhead between the main and reserve portions of the tank.
Preparing for riveting.
More later.
