It might help if you posted how large the part that you have to form is.
It is not that hard really. Plan on throwing away your first try, but you will likely get an acceptable part on the second try.
I would not resort to hot oil. Hot air us good enough. I did the skylights for a Globe Swift in the kitchen oven. You might consider building an insulated box on the front of your kitchen oven to extend its size. Use the oven temp control to creep up on the right temp. Patience is important.
