Results 1 to 10 of 12
Thread: Tables?
    Tables?
    Other forums I visit that use vBulletin have a table-building function. Since I occasionally post statistics-based data, I find that really useful.
    Example:
    http://www.homebuiltairplanes.com/fo...741#post363741
    However, it does not seem to be available on the EAA Forum pages. Can we get it enabled?
    It's a vB addin http://www.vbulletin.org/forum/showthread.php?t=107985 rather than just a switch you can turn on.
    Example:
    Looking into this for you!
    Chris In Marshfield's Avatar
    Germantown, WI
    Just trying this out...
    This is a table row
    This is another table row
    Yep, it works
    If you don't mind doing your own code, or save an Excel file as HTML and do some create find/replace with your text editor:
    https://www.bbcode.org/examples/?id=14
    Still trying to figure out borders...
    ~Chris
    Germantown, WI
    If you use the advanced
    editor, you can create a table and
    add borders at will.
    I don't know if it's a recently added feature or not.
    It doesn't seem to want to let you span a cell across columns or rows, though.
    I wrote a VisualBasic program that converts Excel to vBulletin, but the vBulletin code didn't work here.
    Dale, what did you use to create the table? I don't see an obvious button in the Advanced editor. Did you write it in HTML vs. the vBulletin code? I tried HTML a while back, but it didn't seem to work, either.
    EDIT: Ping! I was in Source Mode, not WYSIWYG mode. I see the options are there in the latter. I'll give it a shot.
    Thanks!
    There's now a table tool bar in there.
