Originally Posted by
JangoFett724
What are wind tunnels?
Chris, You should really goggle it first and then ask if you don't understand. All the detailed information with illistrations is readily availiable on the internet and it helps you learn and understand better. Also, it helps you communicate with others on a higher plane when you do ask questions.
Chuck
