Auto spark plugs are used with electronic ignitions such as Lightspeed because they can tolerate larger gaps that go together with the higher voltage that these systems produce. Both spark plugs and caps can be found that have solid ends or threaded ends. Just be sure to match the caps and the plugs.
The auto plugs work well and they are MUCH cheaper than aviation plugs.
