Biggest Homebuilt Evah
Check out N131CW: Convair C-131, listed as Experimental Amateur-Built.....
https://registry.faa.gov/AircraftInq...umberTxt=131CW
Must have used the quick build option.
Don't think an O-320 would get it even moving on the ground. Might take a half dozen or more.....
Interesting enough, we built a bunch of F-16's that were registered as E-AB's.......
