Thanks for pointing this out, I didn't realize. I've submitted a comment noting that the RV series has the lowest accident rate of the homebuilt fleet, and suggesting raising the limit to point where RVs are included. Included an attachment; a KITPLANES article where some jughead proved that. :-)
If they would just change the stall limit to VS0, it would include most RVs and a lot of other aircraft. VS1 is not a typically "spec'd" limit.
Mel, DAR since the Last Century, Specializing in Light-Sport and Experimental Aircraft. Certificated over 1,100 Light-Sport & Experimental aircraft.
