"stall speed than the planned 54 kcas. "
I read somewhere that this is the clean stall speed (VS1), and as is would rule out the Piper Cherokees. I may not be correct though.
Minnesota
Remember, this is a notice of PROPOSED rule-making. The issue about including Cherokees and RVs in the category is a good one to comment on. You submit a comment online via:
https://www.federalregister.gov/docu...n#open-comment
Don't for a moment think that comments on an NPRM don't matter. Almost twenty years ago, the Light Sport NPRM specified a maximum stall of 39 knots and a gross weight of 1,200 pounds. Both were raised after the comment period.
I reviewed the tables and came away with one point.
► Light Sport Crop Dusting!
John "J.P." Adams
EAA 1379403
“I fly because it releases my mind from the tyranny of petty things.”
– Antoine de Saint-Exupery
Thanks for pointing this out, I didn't realize. I've submitted a comment noting that the RV series has the lowest accident rate of the homebuilt fleet, and suggesting raising the limit to point where RVs are included. Included an attachment; a KITPLANES article where some jughead proved that. :-)
Mel, DAR since the Last Century, Specializing in Light-Sport and Experimental Aircraft. Certificated over 1,100 Light-Sport & Experimental aircraft.
