I was working on a post in Warbirds, about 5 min in the editor. When I went to post I was dumped to a "need to log in" page. Hitting the Back button just bumped me to the same screen. All work on the post was lost.
Suggestion: set the "inactive" auto logout to a longer period, at least 15 minutes. Also, if there is a way to suspend the timer while in the editor, that would be good as well.
Thanks,
Not sure if you want to do this or not, but when logging in, there is an option you can click that should allow you to stay logged in more or less forever. When you come back tomorrow, you can go straight to the forums, without logging in.
