People with extensive experience with VW engines will tell you that 65 HP or thereabouts is about the maximum sustained power setting for the engine unless you want to overheat and cook it relatively quickly. Unless AeroVee could show data demonstrating they have solved that problem, I'd be leery of putting the Aerovee in an application that needs a hundred horsepower engine.
