What bearings for Cleveland rim?
I bought Cleveland rims 600-6 Type 3 for a plane I'm building. I have 1.5" axles. I think I need Timken bearing 13889, and the snap ring. I'm not sure about any other parts such as cup, cone, felt or other rings or where to buy them. I can find the bearings at AS&S, but not the other parts (just the cup, if I even need it).
Thank you!
John C
I think that the Aircraft Spruce website has a pretty good exploded diagram of the 6.00x6 wheel parts. Yes?
While not a direct answer to your question, I bought new bearings for a set of McCauley wheels from qualitybearingsbeltsandchain.com. The LM29749/LM 29710 sets look nice, though I haven't flown them yet. YMMV.
Find the Timkin part number for the bearings, then look around at prices.
Thank you. I ordered four snap rings 155-00100, eight grease rings 153-00900, four Timken bearings 13889-20629 and four grease seal felt 154-00800. I hope it works.
