Page 7 of 11 FirstFirst ... 56789 ... LastLast
Results 61 to 70 of 102
Thread: Goodbye Free SOLIDWORKS
  1. #61
    Sep 2021
    Folks should note that this is the "Design Expert" version of Alibre, which supports CAM features. The "Atom 3d" version is $150, and generates files compatible with my 3D printer.
    Ron you are correct. I did the trial of the Atom3d and found it to be very easy to use. Originally I was going to get the Atom3d version but after using it I decided to do a trial of the Design Expert version. I liked it so much I just went ahead and purchased the Expert. I should have made that a little more clear. If someone doesn't need all of the features of the Professional or Expert editions the Atom3d version is very nice.
  2. #62
    "War-Torn" Portland
    Quote Originally Posted by gwbruce View Post
    Oh, not a problem. Had just paid the $150 for Atom 3D, and it took me a moment to note that you were referring to the Design Expert version. Wasn't sure if others would realize the difference.
    Can you give us an idea of what the Design Expert version provides that isn't in the 3D version us commoners buy? :-)
    Sep 2021
    Ron I'll try. There are the common things that you can find in the "compare" on the Alibre website. Expert has sheet metal and the global variable capability. I can't remember if Atom3d has BOM in the drawing or not. One of the big things for me was the hole feature. In the sketch mode I can use the hole feature and put holes in with the c'bore or counter sink and assign it a thread. Then when I do a drawing and dimension the hole it pulls in the thread, the depth and c'bore info all at once. I do a lot of stuff that has bolt patterns and stuff like that so that is handy for me. There a few more sketch features in expert that aren't in Atom3d but right off the top of my head I can't remember what they are. I am currently at work and don't have access to Alibre. I did the trial of Atom3d and liked it very much. It was just that Expert was closer to Solidworks which I use everyday at work so it seemed to kind of meet my needs a little more. It was probably overkill for what I really need but I was in a position to be able to afford it so I just went for it. If I hadn't been in the position I was in I would have purchased Atom3d with no hesitation. Not sure if that answered your question or not. Once I get home I'll get on the computer and open Alibre and see if I missed anything.
    Gary
  4. #64
    Jan 2013
    Brainerd MN
    As far as "...the usual combinations of sketches, extrusions, etc." is concerned, this is an issue of expectations. There exist international standard cross-platform translators - IGES, STEP, ParaSolid, etc. - that translate basically only the final geometry without the engineering intent and history of how you built the geometry. The history protocol does not exist in any of these translators. SolidWorks, Alibre, FreeCAD, and Blender are not exceptions. Furthermore, the intimate connection between part files and drawing files, as well as mates in assemblies also get lost in the transfer.
    That's the bad news.
    Good news: I've been trying FreeCAD and I find that STEP files go across just fine, although the modeling interface takes a little getting used to. The program also includes FEM/A modules that I want to use. Obviously it isn't as mature as SolidWorks, it certainly doesn't have a massive user base, but equally obviously the developers are doing a pretty good job coming up with regular fixes and improvements. It seems to me that FreeCAD is engineering software developed by engineers for engineers. IMHO this is definitely a viable alternative to SW.
    Jeffrey
    Jeffrey,
    This has been my experience too. I came from FreeCAD originally (OSX/LINUX) versions and have been using it since 0.14. My EAA geek buddies/engineers convinced me to switch to SW about 6 months ago for a panel re-design. It worked, but I haven't invested the time to really get to know SW. FreeCad has worked well in other research designs, but has fallen short of some of the SW widget creation. It is improving rapidly. I use it for creating the MESH I need to drive my 3d printer and for exchanging my drawings with the "professionals." What I really like about FC is I can write a few lines of Python code to get parametric modeling/drawing of complex curved surfaces. Never did learn how to do that with SW so I brute forced the curves. But, then, I'm not a professional draftsman.
    I just got through buying a Win10 PC to run SW and ran into the new version. Glad I checked here before spending even more money. I do have other uses for the PC so it's not a complete waste. I ran SW on a very fast but older MacBook PRO using Parallels, but it was a bit slow and clunky as it is a non-native Mac program so I had to use Windows Parallel, another expense. I also ran SW on a Win10 notebook which ran it modestly better, but no so much so that I would bring both the Mac and the Win on trips.
    I have re-installed FC on the new workstation and it seems to work pretty well. It is not as mature as SW, but I think it has a lot of potential and I've seen a lot of improvement over the past 7 years or so. I think if given the choice of paying for the limitations of the new SW/cloud or donating an equivalent sum to the FreeCad gnu licensed version, I'll donate to the FreeCad Project. Or maybe a little more since I won't need Parallels to run FreeCad which does run on both platforms.
    Does anyone think the EAA might consider setting up an alternative CAD section like they did with SW?
  5. #65
    Sep 2021
    My license expires in January. Can I still take the CSWP?
  6. #66
    Nov 2021
    I agree that this is incredibly unfortunate. Besides Fusion360, have you guys tried out SolidEdge? There is a Community Version (free) for Hobbyists that might help out.
  7. #67
    Eric Page's Avatar
    Toledo, WA
    WEBINAR: Special SOLIDWORKS Offer For EAA Members
    Tue, Nov. 23, 2021, from 7 - 8:30 p.m. CST
    Presenters: Brian Hillner and John Martorano III
    SOLIDWORKS is a world-class design tool leveraged by countless manufacturers and suppliers within the aviation industry. A new offer is available for EAA members, which includes 3DEXPERIENCE SOLIDWORKS and the new pure-cloud 3D modeling tools. Design on a Mac, tablet or smartphone — whenever and wherever inspiration hits. Excited to hear more about this special offer? Join two SOLIDWORKS experts Brian HILLNER and John MARTORANO III as they explore this new offer and give a LIVE design demo, using only the new cloud tools! Qualifies for FAA WINGS and AMT credit.
    REGISTRATION LINK
    Eric Page
    Map of Landings
  8. #68
    Nov 2021
    Hi Eric,
    cloud and no CAM anymore - two exclusion criteria!
  9. #69
    Nov 2021
    SolidWorks (Dassault) works in the meantime just like e.g. Fusion360 (Autodesk). We hobby designers, aircraft builders, private users are lured with a very good CAD system and super conditions. We rely on the promises and work our way into the system. Yes and suddenly the reins are tightened, substantial restrictions, no private data on the own PC (SW), extreme restrictions in CAM (F360) or no CAM at all (SW). But running costs for the general use of the CAD system.
    But in return, fuzzy promises from the manufacturers or their lobbyists. I for my part have decided in any case. Away from SolidWorks, away from Fusion360. I already spend more than enough money on my machines. I also want to get something back from my hobby and not feed the CAD industry in their greedy way. Get the money from those who work professionally with CAD and earn money with it, but not from us hobby designers. I had expected more from the EAA. However, the EAA treats this topic very half-heartedly to not interested. Too bad, I would have hoped for a little more commitment.
    I will now deal with FreeCAD. A free system, which can be used very professionally, runs stable and has earned the support of the community. Everything I need for my airplanes is there: Professional 3D CAD and CAM, united in a living and constantly improving system that is not tied to just one operating system.
    Peter
  10. #70
    Israel
    Hi Peter,
    Words cast in rock
    To some extent I feel insulted by the situation, having spent no small effort and time supporting the EAA & hobby users of SW for nearly a decade. And in return receiving this slap in the face.
    Let's change the name of this EAA forum topic from SOLIDWORKS to FREECAD.
    Follow me - I'm right behind you
    Jeffrey
