Results 1 to 4 of 4
Thread: Wi-Fi locations 2021?
    I don't see any wi-fi locations on the 2021 map. Will the wi-fi be the same as 2019?
    Ok, I see they have two different grounds maps for some confusing reason? So the Wi-Fi locations are on one map and not the other.
    Jul 2019
    KLDM Ludington, MI
    I found the maps, but I wonder what is the difference between a wifi station and a wifi hotspot? Do they both radiate wifi signals?
    I think the station might be hard wired and the hotspots are mobile, but not sure. Should work either way.
