I second being at Fisk at 0700. Traffic is light first thing and the arrival is easy. I have also done the NORDO arrival at 0700. Even easier. Only saw one other airplane on final. You have to write in.
That said, as a courtesy to the other pilots a Cub driver might consider arriving at Fisk at the fastest cruise speed that you can stand. There is no law of physics that says you have to slow down before short final.
