I would like to enter into solidworks a rib shape using the XYZ curve tool...ive included the rib shape with dimensions....does the above information apply to this also...Ive tried to enter the dimensions into solidworks manually but I get modern art and not a rib shape...so I~m doing something wrong...is there a good write up on this xyz tool to understand it better. I`m a little baffled how the xyz numbers relate..
Thanks
