I'm not sure they would consider this a problem. Drawings are typically not meant to be templates. There are a lot of potential inaccuracies introduced when you print something which is why drawings are meant to be read for their dimensional info and not scaled (measured) to obtain dimensions.
You can use printed drawings as templates for non-critical stuff like wing rib profiles to make wooden ribs and some plans do that rather than provide dimensions. Even pounding out aluminum ribs over hand made forms could be done this way. Anything considered critical should be done using better methods IMHO.
