If you have an experimental I don't know why you would opt for the tail or wingtip mounted Skybeacon. The whole thing with the skybeacon is a fast install time for certified aircrcaft.
The EchoUAT is more feature rich and less expensive. You can install one in a few hours.
It is small enough to mount on an inspection panel and have the GPS located out in a wingtip.
