The Texoma Aero Club has a unique aircraft in its fleet. Do you know what it is?
I cheated and looked up the N - lol. The plane is 20 years younger than I am.
I recognized the make by the tail, but I had to cheat too. The plane is 6 years older than me
I don't know about the year, but the vertical fin is the giveaway.
Larry N.
Mooney bought the rights to the Ercoupe in the 1960s, and of course had to change the tail to conform with the rest of the fleet.
They called it the M10 Cadet. This all happened the same year my first Daughter was born. I remember it well!
Mel, DAR since the Last Century, Specializing in Light-Sport and Experimental Aircraft. Certificated over 1,100 Light-Sport & Experimental aircraft.
Interesting history, I had to look it up. From what I read, the tail redesign was not just Mooney marketing. They marketed the plane as a trainer and therefore, it needed to be able to spin. The Ercoupe/Alon A-2-A would not spin, so they changed the tail. The shape of the vertical stabilizer is, of course, al marketing/branding.
You are correct!
I guess that I'm just old - I knew that one right away. As I recall, there were two M-10s based at the airport where I learned to fly in 1977.
