Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Tied Down Outside In A Coastal Area?
    Sam Buchanan's Avatar
    KDCU
    Quote Originally Posted by Marauder View Post
    I can only speak from experience that my car is 19 years old and certainly doesn't have hermetically sealed connectors in the harness and switches yet continues with no electrical issues due to environmental conditions.
    Glad you've gotten good service from your chariot. The late model connectors I've pulled apart usually have a rubber boot and/or some sort of grease on the contacts. Unfortunately, the service depts in many dealerships are not as reliable as the wiring.........
    Sam Buchanan
    The RV Journal RV-6 build log
    What badly corroded wing...that was accident looking for a place to happen. Guess there was a reason for Cessna to start adding corrosion protection. Local flying club replaced its 172 wings at 10k hours. I see Cessna now has a Special Inspection document going out to 30k hours. WOW!!! Personally I think 10k hours is a good mark to have the wings replaced and I would check the horizontal stab spar too. I suspect the landing gear torque box is also a susceptible area for fatigue and would have to be looked out at down the road., especially for trainers with a high number of landing cycles.
    Jun 2018
    ATL
    Scary stuff there, thanks for posting this video. Don't know when it was made but one thing that kind of surprised me was a shop so deeply involved in inspection/repair didn't already have a borescope.
    That suprised me too.
    1978 Grumman AA1C w/O-320
    Sep 2011
    My car is an 18 year old low-budget vehicle and all the connections have some sort of overlapping boots that are tight fitting. The ones that get pulled apart from time to time for maintenance, like headlights, are made of rubber. I'd be very surprised if your 19 year old car doesn't have same.
    To be more particular about my original comment about connector corrosion--- this does not seem to be a problem for connectors like ring ends that are clamped together tightly. Paddle ends that are male/female and can be pulled apart definitely will corrode. I live in a coastal area and have had this issue with every one of my 3 planes. And even a ring connector, if a little loose, will also corrode. Found one behind the panel recently. Yes, that was a hair-pulling, new cuss words adventure in finding out why more than 1 but not all electronic gizmos were acting mysterious. Quite a relief tho when 10 cents worth of electro-spray and a screwdriver solved the problem!
    Feb 2020
    Quote Originally Posted by flyrgreen View Post
    The connections under the dash are for the most part blade type contacts in plastic housings with no rubber boots and after 19 years things still function as intended. The only issue I've had that seems environmental is on mornings when there is a lot of condensation, I may have to drive a mile or two with the radio on before the CD player works properly which I believe is due to condensation on the laser lens needing the heat of the radio to evaporate, not necessarily salt in the air. I've had this happen with two Bose auto systems so don't know if it's the norm for CD players in general.
    I also received the following from an associate of CX-4 designer Dave Thatcher: " Dave's original 4 was tied down outside here in Pensacola /salty air for ten years with no appreciable corrosion. It was 1 mile from the bay and 7 miles from the Gulf." Of course that's with a 6061 T6 structure as opposed to the more common factory (I believe) 2024 T4 structure.
    While I have no doubt marine air isn't an ideal environment, I continue to see many aircraft tied down outside. At times it seems pretty much a crap-shoot as to what the results may be.
  6. #16
    FA40
    "The Cleaning and CorrosionControlmanual was established jointly by the Navy, Air Force, and Army as a combined effort to consolidate and coordinate corrosioncontrol best practices for aircraft and avionics."
    https://www.navybmr.com/study%20mate...1-1A-509-1.pdf
    https://www.navybmr.com/study%20mate...1-1A-509-2.pdf
