Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Converting Certified Aircraft to Experimental
    N404CX's Avatar
    Los Angeles
    I have often wondered why old airplanes rotting away on a ramp don't get bought up and converted to experimental, as a means of less expensive restoration.
    I stumbled across this page, http://www.v8seabee.com/regulations/united-states.html , which described in general how to convert an old salvage plane to experimental.
    Has anyone followed this route with their project, and if so, has it been as straightforward as that article would imply?
    Thanks in advance. -glen
    "War-Torn" Portland
    Note that it converts it to Experimental Exhibition, not Experimental Amateur-Built. That means more restrictions, depending on the FSDO. For instance, your operating limitations may prohibit passengers, or require permission for every flight over a given distance.
    After some high-profile cases, the FAA is sensitive to folks trying to put type-certificated aircraft into Experimental category for recreational use. Best advice that article gives you is to get permission from the FSDO *before* starting work on the airplane.
    Ron is right about how things are now. However, wasn't there a proposal floated around about an owner maintenance category (someone like what the Canadians do)? What happened to that?
    Quote Originally Posted by N404CX View Post
    Because there is no practical method for doing this.
    While it may be possible to do what they describe, it won't be anything like owning/operating an experimental amateur-built aircraft.
    N404CX's Avatar
    Los Angeles
    As the old saying goes, "If it sounds too good to be true, it probably is." Thanks again.
    While I don't think that the FAA is going to help anyone move a Piper/Cessna/Mooney into the Experimental Exhibition category, I will note that operating that type of airplane is really not that difficult. Every spring you send the FSDO a "Program Letter" listing the big fly-ins that you will be going to. Most operating limitations for the more common Ex Ex aircraft no longer have an operating radius distance limit for "proficiency flights". So its pretty easy for something like the Extra 300 like a friend owns. Its more if you own a Mig-21, but its just some paperwork. And a friend just moved a Acrobatic Category Extra 300S from a standard airworthiness certificate to an Ex Ex one to install a non-certificated prop. So its do-able, but I will agree that it is not for your average recreational pilot.
    The good news is that taking a pile of rust and tattered fabric that has a normal category airworthiness certificate and rebuilding it back into an airplane that will take you to OSH some year just requires persistence and planning. You regularly read success stories in the magazine. So if you get satisfaction from getting your hands dirty and have some patience, do it. The journey is the reward.
    Nov 2018
    My C172 is experimental exhibition and although it's not all that easy to switch standard to experimental, for me it was well worth it. My operating cost is less than $20hr compared to over $60 with original o320. It's a V8 that out performs and has all modern bells and whistles, and no mixture control or carb heat....a great upgrade. Exhibition operating limitations are pretty much standard nationwide now and closely resemble that of amateur build aircraft after the phase one flying requirement. So, it can be done, but you will need a good DAR to help.
    Auburntsts's Avatar
    Tampa, FL
    You say your OPLIMs closely resemble E-AB OPLIMs. What are the differences? Just curious.
    PP ASEL - IA
    RV-10 N728TT - Flying
    EAA Lifetime Member
    WAR DAMN EAGLE!
    Nov 2018
    Only real limitations difference is having to fax a list of events I plan to exhibit the plane once a year. You are not required to attend any. There's no geographic area limits after phase 2 and proficiency flying and even non compensation training is allowed, as well as IFR. With the current auto gas about $1.50/gal I'm flying it for less than $17/hr including reserves....original O-360 cost would be over $60/hr.
    Auburntsts's Avatar
    Tampa, FL
    Quote Originally Posted by Skydawg View Post
    I dunno, that actuality sounds pretty restrictive to me -- If I understood correctly you can only fly to events you fax in or local proficiency flights. While that may be OK for some, it wouldn't work for me as it limits the utility of having a plane which for me is more than simply boring holes in the sky and turning fuel into noise. I guess it boils down to a matter of perspective.
    Any restrictions on pax?
    PP ASEL - IA
    EAA Lifetime Member
    WAR DAMN EAGLE!
