Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Cutting Square Holes
    Feb 2014
    I’m talking about 1/4 inch plywood (marine grade).
    For that job I would use a router. With a router all your holes will be exact copies of your master template, insuring a perfect fit.
    Brrrmidji , Minne-SNOW-ta
    Never did find out how big this square hole was...
    It would make a difference about how it was approached ...
    This was drilled at the corners so I could FIND the hole after the Mahogany skin was epoxied in place
    The router with a bearing pilot for a guide , made EASY work of cleaning the edges
    Later I cleaned the corners with a file.
    Try 3/4”x 4 1/4” for starters. All corners are square.
    Marietta, GA
    Dave, what are you cutting? Ribs for the Fly Baby, or???
    You're always welcome to use any tools I have.
    "War-Torn" Portland
    Don't have to cut square holes for stock Fly Baby ribs. They're formed of three separate pieces, joined by a cap strip.
