Dana, the listing from Courtesy says Hirth engines, not Rotax. I was mistaken about the radial part, I thought I saw them that way at Oshkosh. The engines are 60 hp so 240 total which doesnt seem bad for an empty weight of only 1800 lbs. And how would you expect it to fly poorly, what do you base that on? Have you seen this plane or better yet seen it fly?
A real B-17 flies very well.
As for ratings, a pilot was flying it at Oshkosh, so he must have had a rating. Maybe all you need is a regular light twin rating to get a Letter of Authorization.
And maybe you guys dont think this plane is extraordinary and want to find negatives about it, but I think it is special.
Talk to the pilot when there isn't a crowd around to find out how it flies. Non feathering props would make it very exciting if you lose an engine which is very possible with four two strokes.
