If engine was not running and any impact loading from prop would be in bending of flange, I would not expect crank to have damage. Certainly you should indicate flange and assure it is within normal runout.
And give a 10X visual inspection for cracks. Tearing down engine for what sounds like a relatively minor impact seems like overkill to me.
