Thanks, Ron. I understand your point, but given the nature of some within the FAA and given zero documentation of the build, I would think that you would have to prove to the inspector that an amateur (ie, you) had done 51% of the work. As you say, the evidence should be intuitively obvious, but obvious just doesn't cut it with some people.
Tom
