So found an early 80's Godwing Ultralight near me. Looked online and found very little about this UL. I did find out that early there was some question about the spar being weak.
As a new-commer to the world of UL is this a good plane to pick up? What is a good price? It is listed for $1500. The motor is a Cuyuna 430. Add says it was never flown just built and then wind tipped it over so some fiberglass repair will need to be done.
If I do get this can you easily add a tach and altimeter? Maybe even airspeed? Ok I think I have gone on to long. Thanks.
Sent from my SM-G960U using Tapatalk
