Al did all he could do,but it did not affect control of the airplane. Analysis showed that turning the yoke or rudder had no connection to the control surfaces, did not move them at all. The only control was by the pilot who came up from the passenger section and operated the throttles, using full throttle to climb and reduce to descend and differential throttle to turn. I don't know his name, be most don't know him either.
