Results 1 to 10 of 15
Thread: A Look at Aerobatics Accident Statistics
    "War-Torn" Portland
    Note... this has been UPDATED with more data. See Post #5.
    For those who don't know me, I do a lot of statistical analysis of homebuilt aircraft accidents. Wes Liu suggested that I take a look at aerobatics-related accidents, specifically those that occur in airplanes not approved for aerobatics, and to low-time pilots trying to teach themselves aerobatics.
    Ran some analyses over the weekend, and post addresses the results. But I'm a Systems Engineer by trade, so I have to document the methodology, first.
    I used my copy of the NTSB accident database, and the accidents I examined ran from 1982 through 2017. I ran a search for "Aerobat*" in both the Probable Cause and Narrative sections. In my experience examining homebuilt accidents, the investigators would use terms like "Loop" or "Roll", but would also use the word "Aerobatics" at some point in the description. I included planes with both Standard and Special airworthiness.
    This produced 795 "hits." However, the use of the word "Aerobatic" in the description does not mean the plane had an accident while performing aerobatics... often, it was a mere description of the aircraft type ("...the aerobatic aircraft had been purchased two years earlier...."). These accidents were eliminated.
    The next step was to eliminate cases where the fact that aerobatics were involved was not a major factor in the accident. This eliminated instances like landing accidents that occurred after practicing aerobatics, etc. I made a judgement call in cases where mechanical failure manifested itself during the performance of aerobatics. If the failure was powerplant related, I eliminated it, but kept cases of structural failure. This last was for obvious reasons, but in a few cases, the root cause of the structural failure was a construction issue...these were eliminated as well.
    I also eliminated accidents that occurred at air shows.
    With this winnowing-out completed, I had 486 accidents left. The next stage was to identify those which were approved for acrobatics, and those that were not. This was not all that simple. Technically, most homebuilts can legally perform aerobatics (there are a few, like most Fly Babies, that have aerobatics prohibited in the operating limitations). But there are some that really aren't intended for acro. So I flagged these as "non-acrobatic aircraft."
    Similarly, many older production airplanes can legally perform aerobatics simply because the certification standard when they were introduced didn't actually ban acro. On these, too, I generally made a judgement call... considering a Waco biplane an aerobatic aircraft, while flagging the J-3 Cub otherwise (I know there are clipped-wing Cubs, etc.) I did have a couple of exceptions to this, considering the Luscombe and the Globe Swift as aerobatic airplanes.
    Plenty of room for argument here, for sure, but that was my original cut. There were several types that I didn't recognize, these weren't included in the comparison.
    Anyway, here are the basic results:
    Non-Acro
    Acro
    Total Accidents
    114
    357
    Median Total Pilot Time
    1117.5
    1700
    Median Time in Type
    112
    95
    Maximum Total Time
    36500
    29500
    Minimum Total Time
    16
    75
    Maximum Time in Type
    6727
    4506
    Minimum Time in Type
    Fatalities
    102
    296
    % Fatal
    89%
    83%
    The first thing that might catch your eye is the comparison between the median total pilot time. The pilots involved in accidents with aerobatic aircraft had about 50% more flying time than those who crashed flying non-acro planes. Oddly enough, the time-in-type relationship is reversed, with the pilots of non-acro planes having a median 112 hours vs. 95. This may just be glitch in the data, or, potentially, it might indicate pilots getting bored with their non-acro airplanes and start playing around.
    89% of all acrobatics-related accidents in non-acro airplanes are fatal, vs. 83% of the aerobatics-airplane crashes. A lot of these accidents occur at low level, precluding any emergency exit. But in the higher-altitude cases there were several instances of pilots using a parachute to abandon damaged aircraft. Someone performing aerobatics in a plane meant for it is probably more likely to be wearing a chute...and an aerobatic airplane usually gives the pilot better egress in an emergency.
    The most interesting result came when I plotted the pilot total time as a histogram:
    This figure plots the percentage of the total accidents for each type vs. the pilot's total flight time. Note how relatively few accidents occur to lower-time pilots flying aerobatic airplanes. A lot of this is probably driven by the fact that few 80-hour private pilots buy Pitts Specials! But it does indicate that a lot of accidents in non-acrobatic airplanes involve relatively low-time pilots.
    But of course, experience is no assurance that problems may not arise. Nor is experience, nor is even the size of the airplane involved....
    "THE COCKPIT VOICE RECORDER RECORDED CONVERSATION OF BOTH PILOTS DISCUSSING AEROBATICS. THE PILOT IN THE LEFT SEAT STARTED TO DESCRIBE THE PERFORMANCE OF A PROHIBITED MANEUVER (APPARENTLY A BARREL ROLL). THE RECORDING ENDED BEFORE DESCRIPTION OF THE MANEUVER WAS COMPLETED. THE AIRPLANE IMPACTED IN A NOSE LEVEL ATTITUDE WITH THE LEFT WING SLIGHTLY DOWN. THERE WAS EVIDENCE THE MANEUVER WAS PERFORMED AT AN ALTITUDE INSUFFICIENT TO ASSURE RECOVERY OF THE AIRPLANE. "
    This was in a Beech 99 airliner, basically a cross between a King Air and a Queen Air....
    Nice work as always Ron, even if the data doesn't present any real firm conclusions.
    Did you also search "acrobat" in the first pass? Could well be that the person writing a report used "acrobatic" instead of "aerobatic", since the former is, after all, the word used in the regulations.
    My Hatz had operating limitations prohibiting aerobatics. Not sure why, I don't know what the policy was in 1987 when it was built, but current policy is for the op lims to say "only those aerobatic maneuvers performed and logged during phase I" may be performed during phase II. No matter that the previous owners had all been doing loops and rolls in it. I applied for and got new limitations for my plane, put it back into phase I for the required 5 hours, and made the required entry listing the maneuvers flown, and am now legal for anything I'm likely to want to do.
    There are many acro accidents, almost always fatal and they are for the most part not done by novices, rather it is usually some of our experienced pilots that do them close to the ground and make a mistake. If you are low a small mistake can be large, too much to overcome.
    Please, PLEASE don't do acro down low with a passenger. Not wives or girlfriends or boy friends or pet cats, and most of all don't do it with kids. I have spun safely, and recovered no problem, but I started at 15,500 over Fon du Lac.
    By the way a stock J3 Cub can spin very nicely and recover.
    "War-Torn" Portland
    Cool, I DID get another 61 hits. I'll add those and edit the original table.
    "War-Torn" Portland
    Based on Dana's comments, I added "Acrobat*" to my search term and got additional data. This is updated, vs. the original.
    I used my copy of the NTSB accident database, and the accidents I examined ran from 1982 through 2017. I ran a search for "Aerobat*" or "Acrobat*" in both the Probable Cause and Narrative sections. In my experience examining homebuilt accidents, the investigators would use terms like "Loop" or "Roll", but would also use the word either of those terms at some point in the description. I included planes with both Standard and Special airworthiness.
    This produced about 870 "hits." However, the use of the word "Aerobatic" or "Acrobatic" in the description does not mean the plane had an accident while performing aerobatics... often, it was a mere description of the aircraft type ("...the aerobatic aircraft had been purchased two years earlier...."). These accidents were eliminated.
    With this winnowing-out completed, I had526 accidents left. The next stage was to identify those which were approved for acrobatics, and those that were not. This was not all that simple. Technically, most homebuilts can legally perform aerobatics (there are a few, like most Fly Babies, that have aerobatics prohibited in the operating limitations). But there are some that really aren't intended for acro. So I flagged these as "non-acrobatic aircraft."
    Anyway, here are the updated result (updated from Post #1)
    Non-Acro
    Acro
    Total Accidents
    128
    383
    991
    2012.5
    Median Time in Type
    98.5
    97.5
    Maximum Total Time
    36500
    32316
    Minimum Total Time
    16
    75
    6727
    4506
    Fatalities
    113
    317
    % Fatal
    88%
    83%
    The first thing that might catch your eye is the comparison between the median total pilot time. The pilots involved in accidents with aerobatic aircraft had about twice as much flying time than those who crashed flying non-acro planes (note that this difference is SIGNIFICANTLY greater, vs. the original in Post #1).
    This update also now shows the time-in-type for both classes to be about the same.
    88% of all acrobatics-related accidents in non-acro airplanes are fatal, vs. 83% of the aerobatics-airplane crashes. A lot of these accidents occur at low level, precluding any emergency exit. But in the higher-altitude cases there were several instances of pilots using a parachute to abandon damaged aircraft. Someone performing aerobatics in a plane meant for it is probably more likely to be wearing a chute...and an aerobatic airplane usually gives the pilot better egress in an emergency.
    (you might have to hit "reload" to get the updated version)
    That's really great info! Thanks a lot! There is definitely a Sport Aerobatics article in that data.
    Great stuff.
    I'll repeat the great data! You're work is always wonderful and greatly appreciated.
    Ironically, I am interested in the data that you threw away. In other words, how many aerobatic airplanes/pilots have fatal accidents while not intentionally performing aerobatics? Again, such as in the pattern (takeoff, approach and landing) and buzzing friends?
    Thanks, the not-so famous Ron.
    "War-Torn" Portland
    Quote Originally Posted by Ron Blum View Post
    Well, it's always hard making such a comparison; I've got about 4400 overall homebuilt accidents in my 1998-2018 database, but only a few dozen of each of several homebuilt types. But here's how the percentages come out for fatal accidents.
    Fatal Accidents
    All
    Pitts
    Skybolt
    Christen
    Accidents
    1059
    16
    13
    13
    Pilot Miscontrol
    30.5%
    31.3%
    23.1%
    15.4%
    Builder Error
    4.5%
    0.0%
    0.0%
    0.0%
    Maintenance Error
    4.0%
    0.0%
    0.0%
    0.0%
    Undetermined Loss of Power
    8.8%
    0.0%
    0.0%
    0.0%
    Engine Mechanical
    3.1%
    0.0%
    0.0%
    0.0%
    Exhaust or Turbo
    0.0%
    0.0%
    0.0%
    0.0%
    Engine Controller/Electronic Ignition
    0.3%
    0.0%
    0.0%
    0.0%
    Fuel System
    1.4%
    0.0%
    0.0%
    0.0%
    Landing Gear/Brakes
    0.2%
    0.0%
    0.0%
    0.0%
    Other Mechanical
    4.2%
    0.0%
    0.0%
    0.0%
    Fuel Exhaustion
    2.9%
    0.0%
    0.0%
    0.0%
    Fuel Starvation
    1.2%
    0.0%
    7.7%
    0.0%
    Carb Ice
    0.8%
    0.0%
    0.0%
    0.0%
    CG or Weight
    1.0%
    0.0%
    0.0%
    15.4%
    VFR to IFR
    3.7%
    6.3%
    0.0%
    0.0%
    Disorientation
    0.7%
    0.0%
    0.0%
    0.0%
    Manuevering at low alt
    11.6%
    37.5%
    38.5%
    38.5%
    Inadequate Preflight
    0.7%
    0.0%
    0.0%
    0.0%
    Fuel Contamination
    0.8%
    0.0%
    0.0%
    0.0%
    Midair Collision
    2.5%
    0.0%
    0.0%
    0.0%
    Turbulence/Winds
    0.6%
    0.0%
    0.0%
    0.0%
    Loss of Control (Unknown)
    4.4%
    6.3%
    0.0%
    7.7%
    Taxi Accident
    0.3%
    0.0%
    0.0%
    0.0%
    Airframe Icing
    0.2%
    0.0%
    0.0%
    0.0%
    Undetermined
    4.7%
    0.0%
    7.7%
    0.0%
    Other
    6.9%
    18.8%
    23.1%
    23.1%
    Obviously, maneuvering at low altitude is a major factor on these aircraft. However, certain other aircraft types have elevated levels here, too. This is a plot of all accidents, not just fatal ones.
    Name:  maneuvering at low altitude.JPG
    Maybe change that to the non-INfamous Ron... :-)
    Ron
    Jim Rosenow's Avatar
    Smithville, OH
    Nice work, as always, Ron! An interesting look into the nooks and crannies!
    Jim
    Why did you exclude "engine failure." Have you never heard of "Tillie" from WW-II and her diaphram for Spitfires to fly negative "g's"? Or an inverted flight tank? Saber jets, barrel roll, Phantoms oblique loop into chandelle. Don't neglect "inverted oiling system" as a missing element in aerobatic capability. This is WW-I stuff. SPADS and Nieuports? And of course can we clump oil and fuel tanks together for two strokes? Gas Turbines are beyond Brinnell with ETOPS and run dry for endurance right side up.
