I’m stripping down an old Lycoming O-320 case to send to the case shop and can’t get out the conical rubber engine mounts. Any tips? I tried prying and pulling with pliers.
It looks like the rubber may have been inserted into a metal sleeve which was pressed into the aluminum housing. Perhaps cut off the rubber on one end and dig out the rest of it with a scredriver or similar and the using a punch collapse. The metal sleeve and pull it out ????.
