Originally Posted by
Eric Brown
OK guys, here's what I wound up doing. Mineral spirits. I know, not water soluble. The project was C150 wings that had been treated several times with a corrosion preventative over many years. A lot of caked on dirt had collected, particularly aft of the rear spar. Some places I could reach in scrape the crud off and the vacuum out the clumps. Wings were NOT on the airplane. Dish soap, engine cleaner, WD-40,ect. did not perform well enough. I sprayed in mineral spirits and let soak for 1 hr. I then used a pressure washer with a 90* nozzle to blast out the crud. Not squeaky clean, but enough to evaluate the wing internal condition. Oh ya, mineral spirits does kill your back yard grass.
