jn-4 jenny
Hello, I have a few original wood supports that mount vertical between the upper and lower wing of a curtiss jn-4. Not sure what the proper name for these pieces are either. My question is whether there is any monitary value or not and if so where would be a good place to start with finding someone that would want them. Im having trouble up loading a pic as it sais I need a token .
thanks jim
I have no idea but just happened to see this on Barnstormers, maybe it's a point of reference:
https://barnstormers.com/ad_detail.p...44&catid=16400
Wing struts or interplane struts would be the correct term.
Yes there is some value to them, even it only for a private display or in a museum.
These guys may have ideas or want them:
http://www.dawnpatrol.org/index.php - Kit planes styled after WW I planes
http://www.antiqueairfield.com/ - In IA, old planes
