FAA takes a note of the "Turn Back" controversy
https://www.faasafety.gov/SPANS/even...aspx?eid=92129
Disclaimer ; opinions of others will vary depending on what they’re selling.
http://the-grand-design.com/
I watched this video in its entirety (even tho the streaming connection was poor). It is one of the best reviews of this topic that I have seen. The speaker gives practical guidance on how how every pilot can determine if the turn back is possible or impossible. That is, he lays out the skills, capabilities, and conditions that a pilots needs to successfully make the turn. He then goes on to lay out how pilots can develop/maintain those skills.
I have to admit that my preflight briefing in single engine aircraft often lacks the discipline required to maximize safety. We all need training and practice to overcome instincts that might kill us.
I used to engage in this as my favorite topic on the boards , since I got banned from most of them I don't any more.
The "never-turners" will be with us for a long foreseeable future. They will keep presenting crashes as their evidence and without the distinction of what the real cause was like the lack/absence of training and of planning for emergency actions, and rows of dead pilots graves who tried it and so on, but there will be fewer and fewer of them.
In the past people relied on the priest in their church as a sole authority on what they should and should not do, later on they submitted themselves to the news gods on the radio and television to feed them the propaganda and official thinking , Times are different now.
The humanity and the technology moves forward , When I started to fly a video like this was nonexistent , yet now there are many on line at you fingertips and anybody can access it if he only wants to.
I can not believe the FAA, with all the talk about LOC turning base to finial, now wants
to open the turn back drill.
I see it as a tempest in a teapot.
When I was in flight training, my instructor and I went over what altitude and airspeed during takeoff would allow a turn-back if the engine failed on take off. It's really all about the turn itself and how much altitude one will lose.
Likewise "to the airfield" wasn't portrayed as "to the spot you took off from on the same runway." It was "the big flat area with the paved surfaces and grass between them."
Frank "try not to hit the FBO" Giger
Do you think the "LOC turning base to finial" is some kind of supernatural event caused by some divine intervention that just happens and then you must die ???
I myself believe it is simply just the lack of skills that can be solved by proper training.
To all others - decide for yourself which way you want to go.
Pilots of homebuilts, at least, have more problems with takeoff/climb than the base-to-final turn.
Note that this graphic EXCLUDES cases where the power has failed. I don't expect power failures on departure to improve the takeoff/initial climb results.....
OK, two part story that I know I have told before in the forum somewhere.
1. When I got my first airplane, a 1975 Warrior I used to go up and play "What if" games, learning the real envelope of the airplane. A big game, developing out of Lazy 8's and wing overs, was, how tight can I turn and how much altitude will I lose turning around after an engine failure. The answer was 300'. I learned through experience that the airplane's stalling speed is much lower when unloading the wings and if you stick to minimum sink airspeed. (This is knowledge I take for granted now, but I was much younger and everything was new.) 45 deg bank was do-able but 30 deg was enough. Then, one day, I actually had an engine failure at 300 feet departing runway 36 and easily put it down on runway 15. (Of course the engine came back to life in the flare and the one thing I neglected was closing the throttle.)
2. When I give check rides for CAP I use examiner's discretion and combine engine out procedures with take off and departure stalls (which should really be stall AVOIDANCE.) Pull power, count one thousand one, one thousand two, and THEN the pilot can apply corrective action. Minimum sink airspeed (think Vx) prop full decrease, while banking to 30 to 45 degrees and the 182 can turn around in about 200 feet of altitude loss. (Note that the plane is still going up for that two second count.) You may not be lined up with the runway, but probably with the parallel taxiway that you wisely turned towards or the grass or some other flat unoccupied piece of real estate.
Like with the first part, it takes knowing your plane and practice. That practice is really a lot of fun, as long as it isn't a real emergency.
