I agree with all the previous comments, but will also add a couple more … one for each fuel to be fair
1. With autofuel (everyone has mentioned no alcohol), there are two mixes: summer and winter. The RVP (Reid Vapor Pressure) is lower in the winter so that cars start easier under colder conditions. The vapor lock issues arise when you burn winter fuel in the heat of summer.
2. The aromatic content of Avgas is significantly higher than autofuel. One has to be careful of rubber parts reacting to the higher aromatics. It is also blamed for some wet wing fuel tanks to leak when it breaks down older sealants.
My two cents,
Ron "in an earlier life worked the EAA autofuel test program" Blum
How lead got into our fuels and how lead was removed or reduced from our fuels are interesting stories...
The story how lead got into our fuels started with high compression
aircraft engines back in 1921... a young engineer fresh out of college
named Charles Kettering started Dayton Engineering Labs Company or
Delco... he invented the first battery ignition systems for aircraft
engines... when protagonists in the field of aviation widely blamed
his battery ignition systems on knock or detonation Kettering
commanded his young assistant Thomas A. Midgley on a investigation of
detonation. motivated as much by a desire to protect Delco's
reputation as by scientific altruism. Midgley worked for months over
his single cylinder engine and famous "bouncing pin" which was devised
to measure differences in detonation pressures. and he soon determined
that detonation depended on both fuel grade and engine compression
ratio. Thinking at first that fuel color influenced knock. Midgley
added iodine to his fuel theorizing a dark-colored fuel would absorb
more heat energy and vaporize more quickly. When the knock diminished
he smelled success, but it did not come in the form . he suspected.
Further experiments forced him to discard the fuel color idea but led
in turn to a long. frustrating line of trial anti-knock additives. GM.
parent company of Delco. encouraged Midgley and his assistant T. A.
Boyd. who in a vigorous program, individually tested more than 30,000
compounds and their discouragement mounted with the list. On December
9, 1921. a chilly Friday. Midgley and Boyd were anticipating the
weekend's respite from their series of relentless, routine tests when
suddenly the engine was not behaving the same at all. Jolted into
disbelief, Midgley had quite literally stumbled onto the remarkable
antiknock properties of an obscure substance called tetraethyl lead.
This proved to be without doubt the greatest single discovery in the
development of aviation fuels; not only did this additive make higher
power possible. it enabled the aeroplane to fly farther on a given
amount of fuel- it gave the aeroplane range- and in turn enabled the
successful engines that dominated aviation until the advent of gas
turbines. In 1967 the remarkable Mr. Midgley was still active as
president of the American Chemical Society.
The story on how lead was legislated out of our fuels started when
Clair Cameron Patterson could not isolate his rock samples from lead
contamination in the lab in an effort to determine the age of the
earth... he was shocked to learn lead was everywhere and developed the
first sealed clean lab to prevent lead from messing up the data...
The University of Chicago developed a new method for counting lead
isotopes in igneous rocks, and assigned it to Clair Cameron Patterson
as a dissertation project in 1948. During this period he operated
under the assumption that meteorites are left-over materials from the
creation of the Solar System, and thus by measuring the age of one of
these rocks the age of the Earth would be revealed. Gathering the
materials required time, and in 1953, Clair Cameron Patterson had his
final specimens from the Canyon Diablo meteorite. He took them to the
Argonne National Laboratory, where he was granted time on a late model
mass spectrometer.
In a meeting in Wisconsin soon afterward, Patterson revealed the
results of his study. The definitive age of the Earth is 4.550 billion
years (give or take 70 million years). This number still stands,
although the margin of error is now down to about 20 million years.
His ability to isolate microgram quantities of lead from ordinary
rocks and determine their isotope composition led him to examining the
lead in ocean sediment samples from the Atlantic and Pacific. Deriving
from the different ages at which the landmasses had drained into the
ocean, he was able to show that the amount of anthropogenic lead
presently dispersed into the environment was about eighty times the
amount being deposited in the ocean sediments: the geochemical cycle
for lead appeared to be badly out of balance.
The limitations of the analytic procedures led to him using other
approaches. He found that deep ocean water contained 3-10 times less
lead than surface water, in contrast to similar metals such as barium.
This led him to doubt the commonly held view that lead concentrations
had only grown by a factor of two over naturally occurring levels.
Patterson returned to the problem of his initial experiment and the
contamination he had found in the blanks used for sampling. He
determined through ice-core samples from Greenland that atmospheric
lead levels had begun to increase steadily and dangerously soon after
tetraethyl lead began to see widespread use in fuel, when it was
discovered to reduce engine knock in internal combustion engines.
Patterson subsequently identified this, along with the various other
uses of lead in manufacturing, as the cause of the contamination of
his samples, and because of the significant public-health implications
of his findings, he devoted the rest of his life to removing as much
introduced lead from the environment as possible.
Beginning in 1965, with the publication of Contaminated and Natural
Lead Environments of Man, Patterson tried to draw public attention to
the problem of increased lead levels in the environment and the food
chain due to lead from industrial sources. Perhaps partly because he
was criticizing the experimental methods of other scientists, he
encountered strong opposition from recognized experts such as Robert
A. Kehoe.
In his effort to ensure that lead was removed from gasoline
(petroleum), Patterson fought against the lobbying power of the Ethyl
Corporation (which employed Kehoe), against the legacy of Thomas
Midgley — which included tetraethyllead and chlorofluorocarbons — and
against the lead additive industry as a whole. Following Patterson's
criticism of the lead industry, he was refused contracts with many
research organizations, including the supposedly neutral United States
Public Health Service. In 1971 he was excluded from a National
Research Council (NRC) panel on atmospheric lead contamination, even
though he was the foremost expert on the subject at that time.
Patterson's efforts ultimately led to the Environmental Protection
Agency announcing in 1973 a reduction of 60-65% in phased steps, and
ultimately the removal of lead from all standard, consumer, automotive
gasoline in the United States by 1986. Lead levels within the blood of
Americans are reported to have dropped by up to 80% by the late
1990s.
He then turned his attention to lead in food where similar
experimental deficiencies had masked the increase. In one study he
showed an increase in lead levels from 0.3 to 1400 nanograms per gram
in certain canned fish compared with fresh, whilst the official
laboratory had reported an increase of 400 to 700. He compared the
lead, barium and calcium levels in 1600 year-old Peruvian skeletons
and showed a 700- to 1200-fold increase in lead levels in modern human
bones with no comparable changes in the barium and calcium levels.
In 1978 he was appointed to a NRC panel which accepted many of the
increases and the need for reductions but argued the need for more
research. His opinions were expressed in a 78-page minority report
which argued that control measures should start immediately, including
gasoline, food containers, paint, glazes and water distribution
systems. Thirty years later, most of these have been accepted and
implemented in the United States and many other parts of the world.
Busy Little Shop: This is a great post!!! ... especially for your second post. I learned a lot. Thanks!
Ron "always learning" Blum
You're welcome Ron...
Larry L
Inventor of a Go Pro mount especially for aircraft external surfaces...
http://eaaforums.org/showthread.php?...y-for-aircraft
2021 Hummel Ultra Cruiser
1952 De Havilland Chipmunk
1994 Honda RC45 #2
https://www.youtube.com/user/BusyLittleShop/feed
https://imgur.com/user/BusyLittleShop
http://www.flickr.com/photos/55532474@N00/?saved=1
http://www.flickr.com/photos/10503451@N07/
http://s1036.photobucket.com/albums/...usyLittleShop/
Since we’re proving that we cannot make 100/100LL without the use of TEL, Is there another potential solution?
So ... at Sun-N-Fun ... one of the major petroleum companies said that they are running tests with magnesium as the octane booster. Any thoughts on that?
Pure magnesium, or some compound?
Should be lighter than lead.
