Yike!![]()
Grove says they will bend aluminum gear to whatever size and "gun barrel" drill the legs to eliminate a brake line. Anyone had experience with them?![]()
The journey is the reward.
The drilled Grove gear has appeared on many RV-8 aircraft.
Thanks Don! Do you remember if those are Piper cowling latches?
