Just too much fun!
Bungee adjustment worked a wonder!
I actually ran down the runway before the landing, floating above it and touching several times to settle them, as some will be tighter than others and I wanted to get them equalized. It dawned on me afterwards that this might not have been the smartest thing, as if they failed I'd of had a very katywhompus set of gear, with one loose and travelling to the top of the axle channel.
But there's a reason why my most common phrase in just about everything with it is "Well, that worked out okay."
