Originally Posted by
Ron Blum
I’d be glad to help with whatever you need. The soaring industry needs more people like you.
Check out Barnaby Wainfan’s current design series in Kitplanes. He’s a great guy.
Start with your payload (people, ballast, avionics, battery, etc.). Contour a fuselage around it. Figure the CG of the fuselage and contents. Place the wing 1/4 chord at the CG of the fuselage (the wing CG will be close to 1/4 chord, too). Wing size will be determined by your estimated gross weight.
FIY, your statement of “primary” glider conflicts with having an enclosed fuselage. And an empty weight of 254 lbs for an ultralight glider is ~100 lbs. over the legal US limit.
Keep going; you’ll get there!
