Re-riveting aluminum holes
After removing a river, there usually is some markings around the hole, sometimes some deformation. Definitely different from its original state, before having a rivet pulled on it. Is there any preparations one needs to perform prior to pulling a river on that hole?
also, as an aside, does a spinning rivet mean it was badly set and therefore not achieving maximum holding force?
Thanks very much for your thoughts.
