I just watched Dick Kohler's latest "Hints for Homebuilder's" about ELT installation and testing.
Does the FAR required annual testing require an A&P or FAA certified avionics shop/technician to sign off the test for a homebuilt aircraft, or can the owner (not necessarily the builder) do the test per the FAR and sign it off themselves?
Thank you and happy flying!
