does anyone know who is making the wood replacement blades for Precision Propellers, hubs.
I have a good 2 blade hub, and need 2 new blades.
I tried an online search and found nothing.
Robert
Robert
I'd talk to Culver Props - http://www.culverprops.com/index.php
While they usually make one piece props, if you have an old one they can probably use it as a pattern and make you replacements.
I have the stubs, so that might be enough, thank you for that suggestion.
it does not hurt to ask.
Robert
The stubs are the critical part, I suspect. The length and pitch of the blade is what they do.
