Tralika, wow. That’s unbelievable. I guess we’re all subject in that sort of case. Crazy.
First lets define UL as you use it. Confirm you are a legal FAR 103 operation. What other experimental aircraft do is no issue. You are not an experimental UL. There is no such thing you are either an experimental aircraft or an Ultralight Vehicle operating under CFR 14 - 103.
Congested area depends on the vehicle you are flying. You need to operate such that there is no undue hazard to persons or property on the surface. IF in a paraglider you can land in the back yard without knocking over the BBQ I maintain that you are OK. If you fly over the railroad (no train) or the power lines with a 100 foot wide right of way, it is not a congested area.
Reference post #9 - I have a photo of Lake Union that I say is congested for the typical floatplane. Doesn't mean I can't fly my UL over it cause I can ditch and stop in 50 feet. Multiple rescue boats would be another 50 feet away.
If the pilot's good, I mean if he's really sharp, he can barrel that thing in so low, oh it's a sight to see. You wouldn't expect it with a big ol' plane like a '52, but varrrooom! The jet exhaust frying chickens in the barnyard!
I think you all are missing something here. I dont have the exact words or the reference to them, but there is a part that says, "except as necessary for takeoff and landing" you cant fly low over certain areas. If not this clause, no one could land at the many airports that are right in towns, like Houston Hobby, Dallas Love and Addison, Montgomery Field,Oshkosh and hundreds more, in Chicago, L A, Miami.Denver. etc.
What case law.
Actually, I think you misheard or the lawyer misspoke. I don't think there is any "case law" on congested airspace. What is true with regulations in general is that if the regulation needs interpretation, the ALJ an then the NTSB and even the district court must defer to the agency that wrote the regulation for the interpretation. Yes, it's a digusting miscarriage of the checks and balances of the Constitution but it's not limited to the FAA regulations.
