Results 1 to 10 of 27
Thread: Light Sport
Threaded View
  1. #18
    Frank logged time flying an ultralight did NOT count towards any certificate. Never has never will. If the FAA would have allowed this then things may be a bit different from what we see today.
    We're both right and wrong.
    Looks like it counted if one logged before 2013, when they ended the permission. Why they put a time limit on it is beyond me.
    https://www.ecfr.gov/cgi-bin/text-id...#se14.2.61_152
    §61.52 Use of aeronautical experience obtained in ultralight vehicles.
    (a) Before January 31, 2012, a person may use aeronautical experience obtained in an ultralight vehicle to meet the requirements for the following certificates and ratings issued under this part:
    (1) A sport pilot certificate.
    (2) A flight instructor certificate with a sport pilot rating;
    (3) A private pilot certificate with a weight-shift-control or powered parachute category rating.
    (b) Before January 31, 2012, a person may use aeronautical experience obtained in an ultralight vehicle to meet the provisions of §61.69.
    (c) A person using aeronautical experience obtained in an ultralight vehicle to meet the requirements for a certificate or rating specified in paragraph (a) of this section or the requirements of paragraph (b) of this section must—
    (1) Have been a registered ultralight pilot with an FAA-recognized ultralight organization when that aeronautical experience was obtained;
    (2) Document and log that aeronautical experience in accordance with the provisions for logging aeronautical experience specified by an FAA-recognized ultralight organization and in accordance with the provisions for logging pilot time in aircraft as specified in §61.51;
    (3) Obtain the aeronautical experience in a category and class of vehicle corresponding to the rating or privilege sought; and
    (4) Provide the FAA with a certified copy of his or her ultralight pilot records from an FAA-recognized ultralight organization, that —
    (i) Document that he or she is a registered ultralight pilot with that FAA-recognized ultralight organization; and
    (ii) Indicate that he or she is recognized to operate the category and class of aircraft for which sport pilot privileges are sought.
    [Doc. No. FAA-2001-11133, 69 FR 44865, July 27, 2004, as amended by Amdt. 61-125, 75 FR 5220, Feb. 1, 2010]
    Joe,
    I am just wowed at the creation and implementation of Light Sport rules - it's one case where the government came up with a pretty darn good solution to a problem and even solved a few more that were ancillary to the issue.
    It made aviation a whole lot more affordable to me, and fit my needs as ideally as if I had written them myself.
