Just tried searching the EAA site for a downloadable weight and balance form with no luck. Would think they would have that easily available. Anyone here on the forum know where to get a blank form?
Unless I am missing something, it would be nice to just be able to download and print the form without all the other stuff on the page.
Glenn Brasch
KRYN Tucson, Arizona
2013 RV-9A
EAA member since 1980
www.airportcourtesycars.com
Would any of these help?
https://www.fs.fed.us/fire/contracti...orms_a-b-c.pdf
How 'bout this? It's an Excel spreadsheet that does all the calculations for you. It's currently filled out for my plane, just change all the yellow fields with your numbers. If it's outside the limits the appropriate numbers will change to red. I had to zip it as the forum doesn't accept .xls files.
OK, here's exactly what you asked for. Only reformatting I did was to put landscape orientation and set the page breaks where they don't chop a table.
I like this, Thank you. Purchased a flying Baby Great Lakes that has had several changes over the years and the weight and balance has never been updated. This will help.
Dana beat me to it, as I also have an Excel file that I made up to not only mimic the form, but does the math.
I have no idea why I had such trouble with the format of it, but I went through several copies before getting it right.
