Hi, All; I understand the ramifications of what I'm about to ask, but was looking mainly for actual experiences from other builders.
Has anyone ever placed a used certificated engine as-is on their project, without rebuilding it? (well, removing the data plate to de-certify it...) As an example, I've been able to find mid-time engines salvaged from hail-damaged planes. No prop strike, etc. Aside from changing the oil/filter, checking the plugs, etc., and assuming good compression, why not just slap it on your airframe and go with it?
