Originally Posted by
Bill Greenwood
Tom, re carbs, read Eric's first post again. The carb was Overhauled, along with mags etc. Then he even tried a complete 2nd carb with No change, No improvement, He doesnt say but Id guess the 2nd card came from an engine where it ran properly.
So we can believe in the improbable that both carbs were, as you say, "messed up" with the same defect or more likely that as much as this sounds like a carb problem it is really something else.
He could take his components, carb, mag etc, and run them One at a time on another engine that has been running well and see if he can duplicate the problem, thus isolating the cause, but that is a lot of trouble.
