Could be anything. But if EAA simply opposes it without offering a solution they won't listen to EAA nor will EAA get a seat at the table.
We already have user fees from FAA. The FAA is billing Airventure for ATC.
The FAA now requires pilot check ride fees and Homebuilt airworthiness fees that were formerly free.
The goal should be to reduce all these fees with automation.
